Power Panel lights in 342
Has anybody replaced the bulbs in the power panel?  I'm guessing it involves removing the door assembly and then the panel itself.  I noticed that only 1 column of labels light up when I turn on the panel lights switch.  It would be nice to have them all light up.  Even better if I could put in LEDs.
  • raybo3raybo3 Administrator Posts: 5,619 admin
    I did this and to be honest its not worth the work to get the panel out and open. Have to take everything apart. IMO
    I have resorted to using a flashlight for a number of years now.
  • LaReaLaRea Member, Moderator Posts: 8,076 mod
    See this discussion:
    http://rinkerboats.vanillaforums.com/discussion/1828/342-switch-panel
    It's either a 2-hour job or a 2-day job, depending on how your particular boat was assembled.
    To me, fixing those panel lights made a big difference.  I didn't really take notice as the bulbs burned out one-by-one over the years.  When I replaced them all at once, I noticed it big-time.
    Sounds like LED will be the way to go.  Don't want to repeat this job from the sound of it.
    I can't find my message from that is relevant on this, but:
    remove all the top screws from the 'upper' shelf..the whole shelf will come off and get you the access you need I think..or at least help.  Either way it is a lot of tedious work.
    Ah, I was thinking I needed to pull the panel itself.  I'll take a look there.
    On mine, there was no way to do it without removing the panel.  The AC side is enclosed in a sheet-metal safety enclosure.  You have to remove the enclosure to reach the bulbs.
    That flashlight is starting to sound pretty good.   :\
    Trust me........ Its a cluster fu@k to take apart. Flash light works great......
