Anchor Lift Bow Roller
Hello
I have damaged my Anchor Lift and Bow Roller on our 2009 260 EC and need to replace it. I have the replacement part but am having difficulties removing the old one. The 4 screws loosened but would not come out and will not re tighten. There appears to be some kind of contact material also used to glue it down. This puppy is staying put and I bet the bow of the boat would be ripped off before it came off. Anyway, anyone have any info on how to remove it? Heat?
Many Thanks
Ben
Post edited by Babyboomer on
Dear Black Diamond
Thank you for the information. I will probably have to try and reach the bolts through where the anchor line is stored. Like to know what they used to glue this down, man its strong. Will try gently using a torch to see if that works. Bigger project than what I thought but I guess that is the way these things usually work.
Many Thanks
Ben
