Outlet voltage
It seems there is a possibility that we aren't getting enough or unstable power. Our tv sound goes in and out. When I plug it in at home, it's fine. I haven't tested with a voltmeter yet, but wondering if anyone else has had this issue.
Sounds strange indeed. I would not rule out interference from some source on the boat. You might try turning everything on the boat except for theTV off and seeing if there is any difference. Including the refrigerators etc. If that makes the difference, all you then need to do it to hunt it down.
Tony
Salt Shaker 342
