Engine Hatch Actuator
CaptianDan
Member Posts: 94 ✭✭
Calling all experts!! Does anyone know the throw of the actuator to open the engine hatch on a Rinker 342 Fiesta Vee? I know the actual length is 17". Thanks!
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
"Pipe Dream"
We made the wing sweep actuator for the B-1 bomber, dual telescoping ball screw actuator. I think it was a 12' stroke length..a monster. You don't want to know the cost lol
"Pipe Dream"
BD, I used to do some work on the bomber as well, at Edwards and TX.
I agree with you all on the 342s hatch. I work more in the 342s than I do in my own boat and they are a real pain. The 2003 has to be the absolute worst and the only way to do anything is remove the pin and tilt it all the way back. 2004 and up at least give you some room in front of the engines.
MT...aahhhmmm, let's talk about length of actuator.
They moved the transom back. On 2003 there was larger 'shelf' behind the transom. I believe this was an area for the outdrives to tuck more underneath. It narrowed the engine room easily 1-2ft. That's a lot of space to add between the firewall and the engines. That shelf also collected water. No difference in cockpit area. I have 3 close friends in my marina that own a 2003, 2004, and 2005 342. Always fun to do some comparing.
You can buy these with setable limit switches just for this reason.
LOL.. So True! My 2014 260 doesn't even go up enough to let me sit with my legs hanging in. I have to lie down on my stomach and reach. Sort of useless.
I'm going to see if I can get it open and then pop off the pin and prop it up higher.
EDIT: Sorry.. just read that this is a "342 thread".. didn't know.
-=Mike G.
2014 Rinker 260EC
Didn't know summit had them.
https://www.summitracing.com/search/part-type/linear-actuators/product-line/eddie-marine-hatch-actuators
