Drain holes in anchor compartment, not working, FV250.
In the winterization process of my FV 250 2003 I removed the anchor and anchor line from the boat and found that in the anchor compartment the drain holes on starboard and port side are mounted to high. Due to this the compartment never drains completely and a 1 inch deep pool of water is constantly present in the cavity below the holes.
I´m not too happy with this and I´d like to fix it.
As drilling new drain holes a bit lower is not an option. Instead I´m thinking of levelling / filling / out the cavity in the compartment, up to about drain hole level, by pouring in epoxy.
I´m a bit worried though that the heat generated by the epoxy might damage the hull.
Any thoughts on this or better ideas on how to solve the problem?
Thanks
Good luck.
Home port: Hammond Ind.
Bondo is a term for automobile body putty used for body repairs.
http://bondo.com/
Dave
