Anodes
rasbury
Member Posts: 8,849 ✭✭✭✭✭
Well, this should get the crowd stirred up, I had no idea......I need to change my anodes as they look rather spent. They do not appear to be very expensive so no excuse for running with ones ate up. I was looking on line as I expected to see this as a simple purchase decision and I see on other sites, discussions going back and forth whether to use aluminum, zinc or magnisium ????? Is nothing not simple????I am mostly in fresh water, for now, but plan to be more salt, do I really need to change the friggin anodes depending on what type of water I'm in?????
Here is an interesting read...
Fit the correct anode material for the waters your vessel is operating in
As a general rule owners should fit the anodes suitable for the environment they most regularly berth in and the following table provides a useful guide:
Some vessels will from time to time move between salt and fresh water, others are berthed within marinas and behind tidal barriers where the water is enclosed and likely to be brackish or even virtually fresh. Owners must be aware of the effects that this may have on their boats and fit the correct cathodic protection system to avoid corrosion.
Not all anodes are suitable for every environment, for example the surface of a zinc or aluminum anode will if left in fresh water for some time become covered with an off white crust of oxide which effectively seals the anode and stops it working even when returned to salt water. Zinc Anodes suffer a similar problem even in brackish conditions whereas Aluminum will continue to operate effectively in river estuaries and other areas of brackish water indefinitely. The consequences of this passivity of the anode are that the next most anodic item within the anode bonding system will start to sacrifice itself which could of course be very serious.
It is therefore very important to check Zinc and Aluminum anodes after any trips into fresh water and if necessary clean off or change the anodes. Should a vessel move into fresh water for more than two weeks Martyr recommends that an alternative anode system is used suitable for fresh water situations.
Magnesium Anodes on the other hand have a much higher driving voltage than zinc or aluminum making them highly suitable for use in fresh water, they will however become very active in salt water where they will probably only last a matter of months. Protected surfaces can build up a layer of off white calcareous deposit which will be difficult to remove.
Magnesium anodes are not designed for prolonged use in sea water and if you are taking your boat into a salt water location for more than seven days (Fourteen days in any one year) you should consider changing the anodes.
This is from the martyr website.
X
I use mine the same way: it lives in fresh water, and only sees salt water for 2-3 weekend or 1-week trips each season. I've been using magnesium for 15 years, and always had good results. The anodes are 50% spent at the end of the season, and I replace them every spring.
I did try aluminum one year on a previous boat. They barely corroded at all, which means they were not doing their job.
Rent?!? Now you're really going to stir up the nest. Don't let RinkerYan read that post.
X
X
So... what do factory BIII's come with? Magnesium (I hope)? Are they clearly marked on the anodes somewhere? -=Mike G.
2014 Rinker 260EC
X
2014 Rinker 260EC
X
For a freshwater boat that only spends occasional weekends salt water, Mg is fine. The anodes will wear faster in salt water, but that's no big deal if you replace then every year anyway.
MT is right -- Mg anodes have special packaging with bright yellow stickers. Can't miss 'em.
Thanks Stodge!
OK, well that just means I'll probably have to swap mine this coming spring before dropping it in being that they are probably aluminum. I highly doubt the dealer would swap them before sale for the water they are going into... I'll confirm.
Thanks again! -=Mike G.
2014 Rinker 260EC
x
