Battery Question
Boatin BillBoatin Bill Member Posts: 22 ✭✭
Just replaced House Batteries with 2 new AGM group 31 Batteries.  Would now like to replace the 2 engine batteries. Should I  replace with the AGM as well or can I get just stick withthe lead acid batteries? My concern is if the charger isolates each battery as it charges or goes thru all at the same time.
Thanks
Best Answer
    you may have to give more details on the charger.  It may only be capable of charging one type of battery at one time.
  • Mercury2005Mercury2005 Member Posts: 141 ✭✭
    I just installed two new AGM bats in my 2006 270 FV, do I need to be concerned about my battery charger?
    If the charger isn't rated for them, then you might want to consider changing the charger to a newer one that can handle the AGM batteries.
    not sure where the battery charger is or how it works, i.e., does it work when genie is running, shore power is connected?
    My boat is 2006 so should I upgrade and if so what is recommended?
    The charger should be located on the wall between the engine room and the aft cabin. If you upgrade, get a marine charger that can handle AGM's as well as traditional lead acid batteries.
    Will the engine alternator charge my AGM batteries without issues or does the isolator solve the problem?
    If it charged the old sla batteries it will charge the agm's. They virtually the same charging profile.
