manual for 2005 350MPI Motor
rasburyrasbury Member Posts: 8,661 ✭✭✭✭✭
Wondering if anyone has an online manual similar to the one in the archives which show printed in 1999. I found today after studying that manual, my water pump was totally different. Now I understand there may not be any huge difference as things have not changed that much but if I have it, I'll  sure look at it instead! I may need to remove the electric fuel pump and concerned about those lines. And I'm a little confused about the MPI/Carb deal. I need to go back to the motor as I thought MPI is multi point injection, but has a carb and book shows 8 injectors...on a car with enjectors you hap a MAP sensor that controls air intake and not a carb but this motor has a carb?
