manual for 2005 350MPI Motor
Wondering if anyone has an online manual similar to the one in the archives which show printed in 1999. I found today after studying that manual, my water pump was totally different. Now I understand there may not be any huge difference as things have not changed that much but if I have it, I'll sure look at it instead! I may need to remove the electric fuel pump and concerned about those lines. And I'm a little confused about the MPI/Carb deal. I need to go back to the motor as I thought MPI is multi point injection, but has a carb and book shows 8 injectors...on a car with enjectors you hap a MAP sensor that controls air intake and not a carb but this motor has a carb?
So, if you have the 350 MPI..you have a throttle body that looks like a carb, but is it is really just the throttle plates to control air flow (just to keep it simple), then you have the injectors to each intake port.
Hope that helps!
I have in my possession both the “MerCruiser Userguide 350 Sterndrive MPI Models” from 2005 (19.6MB) and the “MerCruiser Service Manual nr31” from October 2001 (6.7MB). Both in PDF format.
The User guide can be downloaded here: https://www.dropbox.com/s/6sfv2wgd89rjf00/Userguide 350 -Sterndrive-MPI-Models June 2005.pdf?dl=0
Anyone interested in the Service Manual can drop me a PM.
// Johan
Johan- sent you a PM message, can you put the link up here for the service manual?
thx!
/Johan
