inverter question time
1994 265 dual batteries with 1=both=2=off switch
I would like to install an inverter. The plan is replace the isolator with a new one (old one is 24 years old and I honestly do not trust it). Then connect isolator to battery number 2 and leave the Bat switch on number 1. In theory this will turn battery 2 into the house battery, and #1 into the start battery (completely isolated from #2). When I wear down #2 I should be able to start the engine without any trouble and charge the dead battery. All with out touching the battery switch.
Does this sound right or am I missing something
Thanks
Steve
mmmm ok should I run a dedicated wire to the stereo (no amp) if so, could I get away with just running a power wire and using the already there ground?
duh after looking at the wiring schematics, all I have to do is move the feeder wire on the battery switch over to the battery #2 lug inside the switch.
Thanks
Steve
http://www.wisesales.com/eu2000ia-honda-generator.html?gclid=CMjK5Oq5xsECFTMQ7AodencAqA
Catch us on Kelley's Island at the Seaway or Portside Marina or Middle Bass at the State Park Marina MOST SUNDAYS and weekends in July! Call My Dinghy on Channel 16.
I run mine in the rear compartment with the door open and a muffler extension.
unfortunately the 265 does not have the back storage area, or the room in the engine area. So it looks like Im stuck with the inverter. I would like to install a 1000 watt inverter. Im thinking that with a fresh start battery and isolator I should be ok. I will acid test everything at the dock before I venture out on the river in the middle of November though. Im thinking that if I turn on all the lights, the radio, and plug in a fan that should drain the house battery fairly quick. Do this without shore power connected and let the battery wear down. Then try to start the engine. If it don't crank, I will know that there is a problem with my wire idea, if it does start, then YAHOO YIPPEE I have a system that will work on the beach.
I will keep you posted
THanks
Steve
If you have only a single starter battery system, this will cut the power when it reaches a lowered-voltage state, but with the turn of a key, it reconnects the 12v, giving you power to start the engine. It mechanically closes the connection at 11.9v. I always had this on my single engine boats, and it got used several times by running it too long on radio and such. Just connect it to the starter battery, and you are done.
because I have OCD so the radio and lights should be on one battery not both so that I do not have to worry about the start battery ever possibly wearing down.
The tv dvd combo, well I like the idea of having one mounted above the locker on the bathroom wall and the dvd mounted inside the locker. Also, because I already have the tv/dvd and the inverter (xantrac 1000), I got them for free from another boat. So why not, it gives us a cheap excuse to go to the marina and play with the boat
