Blue Plastic Drain Plugs
picturethis
Member Posts: 103 ✭✭
Do these need to be replaced when they start turning colors on the threads? I took all 5 of these plugs out today and 2 had the threads turning white, Id imagine from heat
anybody break one off trying to spin it off?
I am a new boater with my first boat, thats why some of my questions seem dumb
yes, they break once in a while. And that usually means having to extract the threaded portion out of the hole since the winged part is in your hand. What's worse is that they have a hole through the threaded part so it no longer provides a seal even if it's in there.
They're cheap so replacing when you see wear or having extras on hand for when they break is a good idea.
