Starter Removal
Well, have to do it.......
5.7 350 with the starter on the bottom of the motor, any tricks to share? Looks like it might be just as easy to pull the riser and all that stuff just right out of the way.......how is it done?? Pulling the motor is not an option!
well,....it is done.
And I made it much worse a project in my mind than it was. It took me I don't know how to get the wire that comes down from the slave cylinder off. Then, the bolts I thought would drop it were the flywheel cover bolts...and then I found, on the absolute bottom of the motor, 2 1/2" bolts. CRAP. And then I put a wrench on one, less than two mins later, was laying on the ground. There are what looks three different styles of starters in the book....this was not that bad!
