Short notice deployment
usafaviator
Member Posts: 41 ✭✭
I purchased a 2007 230 CC this summer with low hrs on it and added about 30 hrs to the boat before I was short noticed deployed. Due to timing and not being prepared I was only able to drain the block and run the engine with fuel stabilizer. The boat will sit for around 4 months till I return. Is that too long for the engine and outdrive to go with the summer oil? Both were changed right before I purchased the boat as well as the impeller. If it needs to be done I can have the wife drop it off to get serviced. Just wanted your opinion. If possible I can do the job when I get home no problem and save about $200. Thoughts?
thanks
thanks
2007 230 ECC 350 Mag MPI Alpha 1
Home port: Hammond Ind.
