SmartCraft/Mercury Monitor on 2007 Rinker 250?
We just purchased a 2007 Rinker 250 w/ MAG MPI 350. Wondering what all is needed to add a Mercury Monitor? Does this boat already have a SmartCraft harness to the dash area?
Post edited by lupinglade on
Best Answer
Nice and Naughty Member Posts: 31 ✭✭
We installed a MercMonitor on our 2005 282BR with the 496 MAG. I had to order a longer cord to reach the plug on the engine but it hooked right up and now I cant live without it.
I'd say you will need the cord to come in to the helm from the engine, it is probably not there. I ran the lines on my previously 2002 310 and now on my 400 (which has DTS, so the conection was in the helm aready). Once you run that cable up, you can connect the monitor up and have a majority of the capabilities without adding more cables. Definitely a great thing to do! My favorite is seeing my water pressure so I know at first sign when my impellers may be weak. Also great if any alarms appear.
I dont have an analog speedo (its through the standard GPS), but everything else is analog (oil pressure, engine temp, tachometer, fuel level). I'd assume the MercMonitor is fully digital signals and thus more accurate, right?
I really want it for GPH & Gallons used, as my biggest fear is an inaccurate fuel level gauge. It doesnt appear that my Standard Horizon 190i links to the SmartCraft to calculate MPG, which is a bummer.
Also what about the engine diagnostics? Does the MercMonitor display and/or store engine codes? I have had some warning beeps here & there and it would be nice to know instantly what they are instead of waiting for the dealer to hook it up to the laptop.
