Engine pulled out = an opportunity to do......what?
I´ve just had the engine pulled out and it will stay out until the spring of 2015.
This means plenty of time to……… to do what???
Anyone having a FV250 knows that it´s has a VERY tiny engine bay hence it´s almost impossible to access anything once the engine is in place unless you add extra joints to your limbs.
It’s a FV250, 2003, Mag 350 MPI, no generator, sea water cooling, Bravo III,
On my to-do-list I currently have as follows:
· Change impeller, inspect/replace/ impeller housing
· Clean the bilge
· Service or replace bilge pump/-switch, add an extra BP (a third) at lowest point in bilge
· Inspect cables, fuel lines, holding and water tanks,
· Replace gear wire, bellows, trim sender and trim indicator,
· ….. your suggestions
Since I´m not planning to pull the engine again anytime soon I don’t want to miss an opportunity due to my own thinking, or the lack of.
This is where you all come in and your experiences.
What would you have done if you would have the opportunity to access both bilge and engine like this?
All thoughts are welcome.
Thank you
Johan
I would also replace the existing bilge pumps with new ones. You might want to purchase a couple of the same ones so down the road if the pump goes bad, you will have one that you know will snap into the housing that is mounted to the bilge. I would also replace the oil pan with an aluminum one to end rust worries. Oh yeah, and clean, clean, clean!
Thank you all for your valuable input so far.
The reason for pulling the engine is bad compression on two cylinders, time to replace impeller, broken bilge pump, need for inspection of elbows, manifolds, risers…etc in the exhaust and cooling system.
When pulling the engine we actually found a broken shutter so both will be replaced.
In Sweden we have no options in terms of ethanol. All gaz have a 10% ethanol content. I always use additive /fuel treatment/stabilizer/.
The engine hours is in the area of 350h.
Now the bilge got it´s initial emergency cleaning, I´ll do the final one in the spring.
// Johan
Ethanol attracts water, which is an issue with boats being in proximity of water.
but.. it is also corrosive to soft lines in the fuel systems, unless there the proper line has been used. below is a picture of proper lines, this one produced by GoodYear, which will not deteriorate internally and cause issues with your fuel systems.
Now is as good a time as any to make certain your floater is prepared to encounter ethanol, which is something not accounted for by engineers (depending on year of manufacturing) and this is an excellent starting point.
The compound of components we call 'octane' is actually in effort to limit the volatility of gasoline. It allows it to be a LOT more predictable when it ignites, and will make it safer to advance ignition timing as well as limit predetonation. When we use fuel that has alcohol in it, we're actually introducing something that is more stable than gasoline, meaning it's equivalent of 'octane' is higher, which would leave a person to assume it's safer for your engine- if you were to believe the propaganda surrounding ethanol, that is. Ethanol has a much more precise (and latent) ignition point, BUT, (big BUT here) it stores less energy than gasoline, AND it burns A LOT faster+hotter.
Since you're stuck with 10% ethanol, there are some things you can do to counter it mechanically, which again, the engineers didn't anticipate when your engine was produced:
- use a hotter coil... 35kvolts is the standard, bump it to 60kvolts.
- use a hotter spark plug. think fancy metals like iridium.
- while using the hotter coil and fancier plugs, increase the gap on the plugs from .043 to .057~.060. YOU CAN ONLY DO THIS W/ A HOTTER COIL AND GAPPING WIDER.
- use a larger core diameter plug wire (many so called performance plug wires are 7.mm+, but that is just the casing. you'll want one with a stouter mantle).
- reduce timing advance. Since your engine is MPI and computer controlled, and since Merc tuned that looking for higher octane recreational fuel, it will advance likely more than is truly safe while burning ethanol laden fuel. You can counter this and not have to re-draft the tune by simply retarding spark at the crank, and by indexing +3* or so. That will take the edge off of the spark, and allow it to be sparked later, which will catch the air:fuel in a tighter compression thus taking greater advantage of compression and stored energy lacking compared to pure gasoline.
I'd still recommend the additive, though. It assists with longevity of the fuel, which is apt to separate quicker.
so.. My contribution to your efforts is: prepare for ethanol, and change timing chain/gears while you're in there mechanically retarding timing DUE to preparing for ethanol fuel.
Thanks
I will consider replacing the fuel hose with ones that is ethanol-safe. Repainting the bilge and adding auxiliary cable-tubes for future us gets right in to my to-do-list. Fortunately my engine is already equipped with a drain plug + hose for oil change.
I´m wondering what to do with the more or less constant pool of water that accumulates on the elevated surface, both port and starboard side, by the transom wall. See area in picture. There is a small cavity where it sits.
Am I the only one with this “feature” and are there any remedies for it? Either to prevent water from entering the area or facilitate for water to drain from it?
BR
Johan
ok, RinkerYan. I suppose you recommend me to level out the cavity completely at the far end, by the hull side, and make a slope in the cavity along the transom towards the centre of the boat?
There is however a barrier at the end, a reinforcement of the transom, just as the elevated shelf drops toward the lower part of the bilge. This would prevent the water from draining completely.
Maybe drill a hole, at an angle, and install a pipe through the barrier and/or/ the end of the shelf?
Is the shelf (the elevated area) hollow or solid?
Any idea why these two annoying cavities exists in the firs place?
// Johan
LG
I noticed two drain holes, marked yellow in pic, that leads me to believe that the elevated area is hollow. An idea might be to open up a hole, on the vertical surface by the drain hole closest to the stern, large enough for an arm to reach in. Then install a very tiny scupper as far in as possible in the cavity and lead a tube from it out to the bilge. The scupper must be as small as possible with a low profile to really fit in at the very bottom of the cavity.
As I believe the elevated area has no constructual (is this a word?) function besides to carry the weight of the holding tank so a 4”*4” hole for an arm would probably not compromise the construction. The tricky part is to know if there are any additional constructions hidden within.
Thoughts on this?
X
