Transom housing/gimbal rings
06 342 with 500 hours
My mechanic has told me that my transom housing is leaking and needs to be replaced, and that the gimbal rings are 'bad' and therfore I may have a pontential steering problem. I knew that the transom housing was leaking and bilge pump seems to handle this problem. Do you know if I can have the gimbal ring problem fixed independent of the transom problem? The quote for these repairs is $10,000. Have you had to have this work done on your boat and does seem like a fair price quote? Paul
is it the transom housing that is leaking or the steering shaft, on my boat I was told that the housing was leaking and after a good trouble shooting it turn out it was the steering shaft which could be replace lot cheaper .I would definitely recommend a second opinion. And yes the gimbal could be fixed independently.
I bought all the special tools to do mine (steering shaft, gimbal bearing ,bellows ,
gimbal bushing ) and all the necessary parts for about 2000$ U.S for both sterndrives.
Paul
gimbal rings video
lot of peoples had good result with their products. Their stainless steel shaft is a bit expensive their are some available on e-bay
Paul
http://www.ghrkits.com/
Dave
