Horn issues
Dream_Inn
Member, Moderator Posts: 7,561 mod
Ok, I know I've seen some discussion in the past on RBO related to fixing the horn. I have the two trumpet looking chrome ones just in front of the windshield. When I push the button, one seems to make a little iniital noise but it seems like nothing out of the other at all. They are usually quite loud (sound like air horns, but from what I can see there ar only electical wires). If I remember right you take something apart and clean it? any help would be great as I do use them since I go thru a bridge each time I leave my marina.
You are correct. There is a set of "points" (remember those??) that corrode over the winter. Just take the rear cap off, clean up the points and reassemble. You should be good to go.
Mark
2019 MTX20 Extreme
use as small a drill bit as you can for this purpose.
You guys are on the ball! That is two great responses very quickly! I will first check out the points & then look at the best place for a small drill tap once I have it working. Thanks!
Anything other surprises I should expect when removng the back cap?? It's a fun place to take things apart (on the round edge of the bow), so hopefully I can keep everything in tact. I can't imagine there is too much that can fall out. A towel or two should hold things there. It's fun to work the small problems that are an easy fix!
Maybe spiders or other critters!! Actually, there may be a cover over the horn motor once you take the back cover off. Just don't lose the screws!
Mark
2019 MTX20 Extreme
2019 MTX20 Extreme
I looked at the 125 Wolo horn. Their website has samples of the sounds made by each of their horns. When I make the decision to upgrade. This is the one I will go with. The only thing slowing me down is the single kazoo type trumpet draws 4 amps and this one draws 8. Of course the boat is wired for the 4 amp load so fixing that is where the real work/expense would be. But someday I will take it on.
Tony
Salt Shaker 342
hmmmm, I could see some good use for it when you go by one of those boats with the lady face down on the sunpad, top unstrapped.
well, Friday was my only day to get to the boat but with the tropical storm, I didn't get out. Planning on taking this Friday off, so I'll mess with it then.
Yeah I tried cleaning the contacts but I think it is gone for good. Even the company only says they guarantee their use for 5 years and I'm at the mark. I just not an electrician and don't know if it will draw too much if I run two horns from the same power source. The more I think about it the more I want to do it (even though it means cutting another hole in the hull). I figure not only will the sound be better but offer the double redundancy we have on so many other aspects of the boat. For now I bought a trusty hand held!
ok, here is the update. I cleaned the contacts and got it all put together and holy crap! I never new it could sound so loud! Coming back yesterday when I got near the bridge entrance, it was so loud echoing that the admiral wondered if I should tone it down. (we all know that won't happen)
thanks for all the help!
but using a nautical chart looking compass as the foundation that looked something like this:
I wanted to do the same thing to my guitars, because it looked so amazing- but then I saw the price tag for what he did, and realized I could just about buy a new guitar (in my price range) instead of doing that..
at any rate- most horns are sounded in aggravating tones.. on purpose.. I think cars use F, for instance, while trains use another all together- and shoot for volume instead..
like I said, I stumbled over this discussion a good while back, and was amazed at the thought that goes into something as simple as a signalling device.. If I recall correctly, there was actually a thought process at one time to have each family of horn using a different tone/note/key, so as they could be identified for what they belonged to by just listening... I reckon, the punch line, is that many folks are tone deaf anyway, and all that is for naught..
