Poor factory wiring
someone must be dealing with issue. 2010 Rinker 296-wired from the factory so the key must be on to use the stereo. Of course with the key on the current draw is unacceptable, killing a big deep cycle in an hour or so. 160+ boats in my lot, not one of them wired this way. Many other wiring issues as well, non abyc compliant, and just plain dumb. I have to wonder if the factory boys ever actually use their products.
wow I just went thru this last weekend on mine (1995 265) I dont know how easy it would be for yours but for me it was pretty simple. I ran a positive wire from #1 battery up to the radio and hardwired it with an inline fuse.
The factory wire harness is a joke no matter what you buy, IE the cigar lighter in my jeep. The cigar lighter is rated for 15 amps, yet they used 20 gauge wire, that is from factory. God help you if anyone has added anything to your wire harness.
It might be in your best interest to get the original wire diagram and make sure things are connected as the diagram says they should.
Can you turn the key counter-clockwise or no? I dont see why anyone would want it hard-wired, as I would think that would increase the risk of running the battery down (forgetting to turn it off). The entire system isnt powered with the key in accessory, just the 12V stuff like the radio, lights, transom shower, and GPS. And any of those can be turned or switched off so there is no draw.
For a fact, 99% of production boats have wiring that deserves at least some tidying up back behind bulkheads and through the chases (Also known as rat runs, but maybe too graphic for the squeamish). A few hrs with a hand full of tie-wraps doing support, re-checking terminal presses and looking for chafe zones is just good sense for any boater.
Mark and JC have your easy answer.
Mike
Yeah... a couple wiring issues with my 2014 from day 1. Windshield wiper shorted out (trips breaker or runs by itself, can't turn it off). Also, all speakers are wired to the front output of the radio, fading to rear results in no sound. Not a huge deal, but it would be nice to be able to quiet down the cabin stereo if someone is napping down there. Also, the cockpit speakers are running off of the amp and the cabin speakers seem to be wired directly to the stereo itself. Oh.. and the amp wouldn't turn on the first couple of hours that used it (that's how I know the cabin speakers run off of the head unit directly), but that seemed to correct itself and has been fine since. It's back at the factory getting all fixed up though, so no worries.
As for the stereo.. I know I have to turn the key to use the stereo, but I can't remember if it's to "accessory" or to actually "on". -=Mike G.
2014 Rinker 260EC
2014 Rinker 260EC
Yeah... I figured as much. It was going back to Indiana anyway so I'm letting them take care of it. I don't have any of the removal tools to pull the head unit either (used to years ago), and I didn't want to try "alternative" methods on my new boat.
I will say, that I thought I would have to upgrade the stereo right away, but it actually sounds pretty good! At slow/no wake or when just chillin' there's even a decent amount of bass too. -=Mike G.
2014 Rinker 260EC
OH! I should have just looked. Didn't have the boat long enough I guess. All I wanted to do was use it before the season ended. I bought it just after the Metro beach boat show in the middle of September. Only went out on it three times not counting a quick couple hours hanging at the marina, before it needed to be sent back.
I might be installing a sub somewhere next year (need more bass in the cockpit), so that's good info for future reference. I just can't convince myself to cut a hole in the fiberglass somewhere.. not yet at least. Plus, I'm not sure how to run wires through a boat... no experience there either.
OK.. I'm getting off topic. Thanks for the info! -=Mike G.
2014 Rinker 260EC
Mike, if you have a storage area under the drivers seat, there should be room for a sub there. In the 280 there is enough room for a 10" sub. I am looking to add one as well and that seems like the most logical area.
Mike, running wire isn't too big of a deal. You will need to fish it, obviously, you should be able to fish it just ahead of the engine compartment and then probably the best way to go is up just behind the helm, where a lot of the other wiring comes out. From there you can follow the wiring into the TV cabinet. You will just have to pull it in about 3 steps. I would start at the TV cabinet and work your way to the sub.
2014 Rinker 260EC
My 2003 310 also was wired to the port key turned left. But I also had an unused ACC switch next to it simple swap over so no key needed to be left in the switch and I can see easily the lit ACC is on when I shut the door. Not that its an issue leave on and draining a battery being on shore power when docked.
