Drain Plug LED lighting
20captiva08
Member Posts: 15 ✭
I have a 2008 rinker 192 captiva and I am considering buying a LED drain plug light but I dont know what size the drain plug is and even if it is a good idea...i would love to get some input back.
Well, I never knew there were different sizes, but I guess there could be. I'd first ask, how clear is the water you boat in? The drain plug is a good ways down there to light much up. I have a light on the transmom, about half way between the plug and the platform. Does just ok and with the beautiful murky water in the chesapeake, not worth much.
The concept of putting it where the plug is a great idea. No holes thru the transom, not much to lose except the cost of the product if it doesn't work well. If my boat was in the caribbean (oh, how great that would be), the light would be really cool!
I installed a liquid lite on my 192 last yr
It was the 6 led one with 1/2'" plug ,
ez to install just tie it into lite in the engine compartment & lite will be on when u have the floor lights on .
Dont expect it to light up the lake , But for $200 I was pleased with effect ..
Or Iboat ? Can't remember?
I ordered the clear lite as my lake is quite turbid
Gives a nice green glow to the transom under the swimdeck
And a meter or so all around it. I like it
I'm sure with clear water it wud b even better.
Go for it u will like it.
That's my project this yr on my 192
I was planning on stickin a couple 8 or 10"
Subs right in ft of each ft seat on the vertical surface
Above the angled footrests ?
Amp location I am not sure yet as I havent pick any yet.
Seen a vid on youtube with amps installed upft on a 192
Not too keen on givin up that storage.
http://www.coastalnightlights.com/orders.html
I used the "DS" version in blue. Lights up the water really well.
You should set the bunks around the same place your trailer holds. There are a lot of lifts in my marina, and on all of them, including mine, they sit in the cradle pretty much the same. As far as pulling forward, the back of the cradle should be within a foot or two of the back of the boat. Here is a picture of my last boat on a lift:
If you look at the other switches in your switch bank, you will see which terminal is the switched +12 vdc output. Use a standard blade-type connector (female) on the wire. As for a ground, you can use any number of ground points in the engine compartment or you can run it up to the helm as well (if you're using a 2-wire cable).
If it bugs you that the switch says ACC, see this post.....
http://rinkerboats.vanillaforums.com/discussion/724/descriptive-switch-caps#latest
Mark
2019 MTX20 Extreme
This may (or may not!) help.
Mark
2019 MTX20 Extreme
