5E kholer generator
Hi
I have a 5E gasoline kholer generator it is gasoline, so the problem I have is that it works for 2 hours after that it shuts down I turn it on and it does it, but it still shuting down many times I tested it with a separate fuel tank and it does the same, some suggestion to solve this problem
Thanks
Thanks
21rene21. Send me your e mail and I will send you the service and parts manuals, they have fault codes and a trouble shooting section.
If you search the forum, I have a laundry list of problems/solutions posted up. Plugs are the #1, note there are (2) of them! If not the problem, then:
* Check the oil..it is picky about the oil being to the FULL mark..do not screw in the dipstick to check!
*Cooling system: clean strainer. Replace impellor. Check coolant level at cap. Check that the overflow reservoir is full. If you let it go dry it will suck in air and it will NOT self bleed out and can/will cause overheat shut downs. I posted up a way to bleed out. You may also need to backflush the heat exchanger to get any trapped impellor pieces out too.
Good luck. it is fixable!!
Thanks
You might also try running it without the service panel on the sound enclosure (of yours has this). Mine will not run long with it installed. It is really no louder with it off than on.
