thru hull water inlet for engines.
Does anyone have thru hull water inlets in 342.
what is best location??
would like to do with engines out???
Could u send me a picture?
Would really help.
thanks, new guy on block.
installed thru hulls,solved problem. (On myOld boat)
hope to do same on this boat.
Well I don't have mercury engines but my raw water pump sucks water thru the thru hulls and drives then thru the motor.
Dual intake is a mixed blessing. If the outdrive pickup gets clogged, the thru-hull provides a redundant path, so that's good. But it also adds risk because thru-hull fittings can fail. It also adds complexity, and of course cost (which is probably why most builders skip it). Do the benefits outweigh the cost/risk -- yeah, probably.
Also, on the 342 it's almost impossible to reach the valve levers way back between the engines.
RANDY342: I'm sure you have already read all the "don't do this" guidance for installing thru-hulls. There are a lot of mistakes that can end badly.
Are you going to add raw-water strainers? To me, that's a bigger benefit than dual intake, but it does make for a complicated and expensive upgrade.
i have had problems in the past with other boats not cooling.
however i think i will leave them alone for now.
aditional holes in my boat does not excite me at this point.
thank u for your input.
need all the help i can get.
