Quick Generator Question
rmrstlmo
Member Posts: 238 ✭✭✭
I believe I inadvertently shut off the fuel line to my generator. It started and ran fine (not sure for how long) then quit. I'm guessing that I need to prime it to get it to start again? Also, is the filter in the photo a fuel filter? Looks huge to me.
Ray
2006 390
Previous 2000 340
Best Answer
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
You probably won't feel pressure at the fuel pump, too small for that. Try running a hose from a small gas can to the fuel pump. Dump in some fuel system cleaner at the same time and run it through.Just to make sure, you know there are (2) plugs in the genset. Always replace both, as note earlier they eat them up even if they look OK they can and probably are bad.Past owner of a 2003 342FV
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
One thing that probably is not in the manual is that these things "eat" spark plugs. Even though the plugs probably look just fine, replacing them may be the solution. That is if the ignition module is functional and is not the problem.
Tony
Salt Shaker 342
Ray
2006 390
Previous 2000 340
Ray
2006 390
Previous 2000 340
well, you're right. I didn't see anything in the 5E manual for bleeding the air out of the fuel line. I know for my genny it is one of the main causes for issues. I hear you on having it ready to go for next time!
