Parasitic Electrical Loads
mvn
Member, Moderator Posts: 763 mod
I was helping a neighbour with his 1999 Mastercraft X-Star. He keeps draining one of his batteries very quickly (only after a couple of days sitting in the driveway). Looking at his setup, he's got 2 Mercury 650 MCA Group 24 batteries hooked up through a standard Perko battery switch. When I asked him what position he leaves the switch in, he said both, even on the trailer.
This is the problem, right? With different internal resistances, one will always drain the other?
I also noted that his Leece Neville alternator with external voltage regulator was drawing 180 milliamps with the engine off. Is this normal?
Thanks,
Mark
Good, fast, cheap.... pick two.
2019 MTX20 Extreme
2019 MTX20 Extreme
It stands to reason that two batteries on the same channel will stabilize between themselves... Unless one is jacked up with dead cells.. or, unless there is a ground hiding out somewhere that slowly sucks the life from one or both.. I may be wrong, but unless that alt has a wingdingyfancy minder, it ought not draw anything unless it is in fact part of the conduit for that ground..
I could be way off, though...
2019 MTX20 Extreme
A dead cell will certainly do that.. if he were to simply isolate the suspect battery with the switch, he could likely isolate the problem to that bank, which makes troubleshooting a lot easier..
2019 MTX20 Extreme
2019 MTX20 Extreme
