HDS5 in GPS spot on 342
Stodge
Member Posts: 2,738 ✭✭✭✭
Someone had asked about putting an HDS5 in the GPS spot on the 342 dash. Our 342 came with that combination already installed. It does hang over a little. I was under the shrink and got a couple pics because I remembered saying I'd provide some when I could.
Turns out the HDS5 was held in place with 5200. The new dash layout will allow room for an upgrade to a 7 inch display down the road. No rush though.
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=4&cad=rja&uact=8&ved=0CDAQFjAD&url=http%3A%2F%2Fwww.sbmar.com%2Fdocs%2FVesselViewManualSept2010.pdf&ei=6w4HVbPwEJTdsATPoIDoCQ&usg=AFQjCNEem-HWrIbLZZrP2Ve3D6du4xmpaQ&sig2=6ojzN0IJMQ2dJiw2eQ_mjg
Looks like there is a newer one also.
