Charging house battery(s) (easy question)
Hey Guys...
Easy one... Do I have to have the battery switch to "combine batteries" to have the alternator from the engine charge both batteries? I'm pretty sure the Shore Power charger charges both, but not sure about the engine alternator.
Can't find the answer in the manual.
-=Mike G.
2014 Rinker 260EC
Best Answer
Black_Diamond Member Posts: 5,439 ✭✭✭✭✭
No, they will charge from shore power / engines, don't put the switch on 'combined'. that's really for an emergency like dead batteries.Past owner of a 2003 342FV
Thank you sir!
-=Mike G.
2014 Rinker 260EC
ok if I may chime in here,
You are at anchor, playing the radio, the fridge and have ALL the lights on. The battery isolator and the way the boat is wired lets the main battery drain from all the stuff playing. When your ready to go, you just switch to the other battery and the engine will start and charge the first battery?
X
X
X
Hey Guys... not to bring up an old post, but just for a final answer and to understand exactly how the new battery switches (the ones with "On" and "Combined" only) work on our boats, here's a video that explains it all very well.
-=Mike G.
2014 Rinker 260EC
Catch us on Kelley's Island at the Seaway or Portside Marina or Middle Bass at the State Park Marina MOST SUNDAYS and weekends in July! Call My Dinghy on Channel 16.
06 Rinker 270
06 Rinker 270
When I took my batteries out I did not look to see which battery was for which. What is the tell tale sign of where to place each battery. I was told follow the wire form the starter and that will be your starting battery. Appreciate the help, fairly new to owning a boat.
06 Rinker 270
Paul
06 Rinker 270
cscott@nauticglobalgroup.com.
There also lots of member on this forum with a 270 that could help you out
Paul
As for your switch settings - you should also be 100% sure what it is doing. There should be a switch setting that has both batteries engaged, with the starter on the engine and the deep cycle on the house. I would change the switch setting and disconnect one battery at a time to learn what switch setting puts what battery on live.
One question still remains... Do I leave switch on 1 or 2?
06 Rinker 270
Well my boat has the new style "Off", "On" or "Combine" switch. On that type, "On" is where it should be.
My past boats both had the "Off", "1", "2" and "1+2" switches. On those, I was told NOT to use "1+2" because of something about the way it charges the batteries (batteries have different voltages and capacities)... and that it could be more work for the charging system. You also may not end up fully charging the batteries that way. I usually used "1" or "2", and would switch every once in while (like one battery one day, and another the next). I don't know if that was the right thing to do, but that's what I did. If I was on the hook for several hours, I would run one for a while, and then switch to the other one. I also checked voltage every once in a while to be sure I wasn't running one battery down too low. If I did, I would start the motor and switch to the battery that was run low to charge it up.
Can anybody answer him definitively? My previous boats only had 1 engine, and two batteries. Those with 2 engines and/or 3+batteries could probably answer better. -=Mike G.
2014 Rinker 260EC
