Transom Mounted Transducer on 262 Captiva
I'm looking to install a Garmin transom mounted transducer on my 2005 262 BR. The transducer says not intended for use with a stepped hull. I assume the 262 is a stepped hull. Has anyone with a 262 or similar style hull done this successfully? If so, where did you mount the transducer?
Best Answer
MarkB Member Posts: 3,991 ✭✭✭✭✭
I had it installed by pros that do many, many transducer installs. I track bottom easily at high speeds. I see fish clearly when trolling. It seems to be the correct place to me.Boat Name: King Kong
