TV's for a 2006 Rinker EC320
Anyone replace their TV with a larger one? Can you share some pics (or email me)? I would like to replace that small (DC) one with a larger AC one (or larger DC one). I would like to see how you mounted it and maybe not have it stick out to much. Also would like to know if you just made a 110AC plug behind it and just put up a regular HD TV and antenna..etc
Thanks
Thanks
Marco
NO, that is NOT my car or plane, but I ALWAYS DREAM BIG
http://www.majestic-global.us/led-tv/32-32-led-tv-with-usb-mmmi.html
It looks great and works really well. I used a hdmi splitter, so the tv's can watch the same thing or something different like play video games on one, watch a movie on the other etc...
And is the outboard down there to power your blender?
I removed the old tv in the cabinet and use that for storage, on top of it we have a PS3 and a blueray player.
to mount both tv's I used this mount: http://www.wayfair.com/Cheetah-Mounts-Articulating-Arm-Tilt-Swivel-Wall-Mount-for-12-24-LCD-ALAMB-XQY1004.html
I had to use a block to extend it out 1-1/2" so it would fit, so I used a piece of 2x4 cut to size and painted it black, you can see it but if you do it looks really good like part of the mount or trim. I through bolted the mount through the wood block and through the cabinet with some fender washers. It is secured really well, and has had no issues in some really rough conditions. One then main cabin tv I modified the mount buy placing both the spacers in the mount towards the bottom, this raised the tv up about another inch to give more head room entering the aft cabin. It now is level with the opening.
The mount was cheaper when I bought two of them, I believe the were $15 with free shipping.
Mine is year older and doesn't have the same type of door on that cabinet. Mine was a tube tv that set inside the cabinet.
Camping World had the Jensen 24 inch for $309. Just got mine last week. Hope to have it in place soon. It is going over the opening for the mid-berth. Got a 12v BluRay player to feed it. It's going where the old CD changer used to be.
I got the Axess TVD1801-19 19" TV/DVD combo. it is a 12vdc TV with a 120vac adapter. I just have it plugged into the existing DC wire so I can watch it anywhere. The picture straight on in great. At an angle, it is just ok, but it works for me. I reversed the mount for the old TV to get the wood part of it closer to the door. If I recall, I needed a couple of washers for spacers and different metric screws to get into the TV. Just be careful on the length of the screws. If they are too long, it will damage the TV. The 19" model covers the hole in the door except for the bottom. There is a 3/4 inch gap from the old TV that is exposed. I used some thick black weather strip to cover the hole and you wouldn't notice it if it wasn't pointed out to you. You could bump up to the 22" model if you want a bigger TV and to cover the hole completely. This winter I did get a mount for the TV so I can change the viewing angle. I haven't installed it yet since the boat is still in storage. I was going to get it out this weekend, but that isn't happening. Hopefully next weekend, so I could get some pictures for you.
I will order the 22 in and see how it works. I hope the old Antenna will work for this model. Thanks for your help.
As long as you are somewhat close to a city, the antenna should work fine.
(hope that is not whats already on the boat), I did not take pic of it. Also odered the Mount above and a smaller FIXed one if it moves too much. Will keep you all posted. maybe in 2 weeks i will install them.
Finally got the TV mounted.
