Replacement lights for a Rinker 2006 EC320 Anyone convert to LED yet?
marcop300
Member Posts: 20 ✭✭
I'm looking to replace these FIRE hazard lights
with some less wattage, more brighter, LED type lights. Anyone do that yet? Do you recommend a brand, type or a site that I can get these from? I don't mind on cutting the cable to run a new type powr plug to it. Would like one that is about 6 inches round. I want to cover over the burn spots. I don't know if previous owner put large bulbs in there but looks like boat could have caught fire.
Please let me know what you had done to replace these. Thanks
Marco
NO, that is NOT my car or plane, but I ALWAYS DREAM BIG
www.optronicsinc(dot)com/PRODUCTS/RVLighting/RVDomeUtility/Products.aspx?SeriesID=314
So your saying, you just replaced the BULB in the same light kit, with a LED? I guess I can order new ones and then replace the bulbs. Most of mine look brown now from all the heat. I want to get ride of all of them. Do you remember the name of yours, that you used to replace it with?
https://www.superbrightleds.com/moreinfo/led-bi-pin/6hp-led-disc-type-g4-base-120-degree/486/
before ordering it could be a bit confusing
http://stores.ebay.com/automotiveelectronicequipment?_trksid=p2047675.l2563 (less)
If not, anyone know which model is needed to replace those bulbs to LEDs?
thanks in advance!
Craig
Thanks for the reply.
@Dirtythirty, I only have my arch lights on while at the dock or while tied up to one of the wharfs in Pittsburgh. I usually go with blue, but sometimes red is cool. I do agree with not having them on while underway. I have a hard enough time with the Clarion remote that is bright as he**. I added the illumination from that to the dash dimmer, which has helped it a lot.
Based in China, 3c-made-in-china has been an eBay member since Dec 29, 2009
