gel coat
Does anyone know what kind of warranty is on the gel coat of rinker boats. I have a 2010 captiva 246 and appears the gel coat is spider cracking. It is not at any stress point of the boat. It is towards the front and middle of the black. It is doing it on both sides in the same general area. you can feel it like its a bump in the gel coat. Am I SOL
This is the issue, it's not so easy to make a claim as it has to be proved that the cracking is not a result of misuse. Was the boat hit in those areas? Are improper tying techniques used? Etc, etc. Almost impossible to prove.
The good news is that it's not difficult to fix. One common issue is that the gelcoat is sprayed on too thick and it can't flex, so it cracks. The solution is to chip that gelcoat off and reapply a thinner layer. A professional could do it in half a day and you won't even notice it was ever repaired. It's actually pretty easy to work with, so if you're comfortable enough you could give it a go. Color matching is the hardest part, the rest is easy.
