Turn the key off...get a strange sound.
So I'm working through the list of problems encountered with this 2005 496 Mag 262 Captiva and wonder what might be causing this issue:
When I turn the ignition key from On to Off...weather the engine is started or not, I hear this loud kinda grinding sound as if something is disengaging at the engine. It dosn't sound like anything that was designed to make a noise like that. Is there something with the starter that engages/disengages when the key is truned from On to Off and back?
My turn key on sound is different, it's the pump pressurizing. The turn off is what I believe is something removing that pressure?
after re-reading your thread here, I'd lean away from fuel issues right now. I'd look more toward greasing your gimbel and/or the shaft and joint leading to the bend, and seeing if that eliminates or reduces your noise. i'd also listen real close to hear if it is happening while the engine is running, but is drowned out by the engine noise. this noise would originate from directly behind the engine.
just my thoughts.
Unfortuantely, this boat came with a whole bunch!! I did discover Saturday that the reason no sink water was discharging from the discharge port was becuase the drain hose ended 4" before it connected to the drain port nipple! Subwoofer wasn't happy to have the sink discharging on top of it! I'd like 30 minutes in a room with the previous owner of this boat!
