Planning on making a custom filler cushion
So, this will be the first "custom" project I undertake. I have found that with 2+ adults and 2 dogs on board I have some wasted space for lounging around. The floor space is nice to have, but usually we are swimming or laying in the sun. So, I decided to make my own filler cushion to create another beam-width sunpad, in addition to the standard one above the engine hatch.
Here's a quick mock-up with cardboard, and I'm going to modify it a little bit. I want to be able to open the cabinet door, as thats where the cooler resides (dont want to get dehydrated!!
Anyways I'll need to get the small cushion that goes in the walkway (or make one) and here my plans for the filler cushion:
1. Use Starboard or maybe marine grade plywood for the base.
2. I have a local source for high quality foam, and I'll likely try to wrap and staple the cushion myself to save $$
3. Utilize the tapered-fit mount on the deck for the post, and install a base on the bottom of the cushion. This way the cushion is separate from the post for easy storage.
4. I might mount some sort of hinged "leg" at the bow end, to reduce any flexing or movement of the cushion. I might wait to see if its needed.
Any suggestions in addition to what I've thought of?
Here's some pics of what I'm planning:
Right now:
Right now:
2013 276 Cuddy ~ 350 MAG / B3
Another thought after looking at your picture again. Shorten the front just a bit forward of the table mount (so it wouldn't tip when sitting on that end) & then add a little piece that went into that stern walkway for support. This would make it very sturdy on both ends. How big is that little lip that goes all the way around? Could you take advantage of that at some spots? Definitely post some pics of your progress!
The standard filler cushion I believe uses two rods, as there are two indents on each side below the wraparound seats. I could use that also if need be. The lower lip is definitely not strong enough to support anything, plus its rounded.
I found a pic of the smaller cushion that rinker makes, gonna see how much it costs as it could save me some headache.
