How to Fuse When Changing Over to LED Nav Lights
rmrstlmo
Member Posts: 238 ✭✭✭
I need to replace one of my nav lights so I'm planning on switching LED lights. I have 2000 340 with the in dash small round breakers. The lights require a 1 amp fuse and the smallest breaker that I have found is 3 amp. I know I could use an inline fuse. Any other ideas?
Ray
Ray
2006 390
Previous 2000 340
2019 MTX20 Extreme
2019 MTX20 Extreme
Mark,
Did you mean to put a link in your response?
Ray
2006 390
Previous 2000 340
He's right about the purpose of the breaker. In the wiring circuit, the breaker is there to prevent a fire FIRST, damage to the load second. Since excessive current draw will create heat in the wire, too much current may cause the insulating material to melt or to ignite (depending on what it's made of). The breakers PRIMARY purpose is to prevent this by limiting the amount of current allowed to flow in a circuit, based on the current capacity of the wire. If your concern is for the load, add a properly sized fuse close to the load itself. This will prevent any other device in the circuit from drawing current in excess of the fuse capacity.
Short answer - Leave it alone.
John & Kathy
2002 FV 310 "pair*a*dox"
2019 MTX20 Extreme
