HVAC unit problem.
All, I had a problem last Sunday when I went down to the boat. I turned the heat on, and got no heat, or water flow. Week before heat worked great. I turned the AC on, and it worked just fine and got water flow. I have a friend across from me who is a HVAC specialist and he took a quick look at it. he said that the reversing valve is kicking in (can hear it click when the unit switches over to heat), but the compressor and the water pump are not turning on. Blower turns on also. He doesn't know much about the marine units, but he suspects from looking at the manuals and some of the diagrams that the problem is with the thermostat unit. Not sure why he suspects this because the thermostat is kicking over to heat and the heat light is turning on, but he thinks that little thermostat is controlling some of these other functions also. I think the manual called it a passport or something like that. Is anyone on here familiar with these units, or ever have a similar problem? Any help would be greatly appreciated. Thanks.
06 Rinker 270
06 Rinker 270
Also I noticed a small about of blue liquid coming out of the pump. Think a seal might be leaking...
06 Rinker 270
