battery of choice?
i am looking to buy 3 new batteries and was curious, what is the battery of choice? from what i am reading, the diehard platinum is the way to go if you want the price tag. i understand that you get what you pay for, but sometimes you get the same battery for less money. i will be purchasing a dual purpose battery for cranking and 2 deep cycle for house batteries. since i don't plan on running the battery switch in "emergency start", using a 24 for cranking and 2-31's for house batteries is what i was thinking. i have an 06' 250 express cruiser and if i turn the batteries parallel with the transom, i should be able to fit all three. thanks in advance for any advice
space concerns can be negotiated, and almost pushed between its 12v kin.. the simple fact is a 6v thick cell battery can be discharged much quicker (starting amperage) and maintain its integrity (needed for house type applications) better than asking a 12v to do the same, and it can be charged much quicker, too- giving you the best of both worlds. you series them prior to the switch, and they are in parallel after the switch, so your charging system doesn't need to be altered.
check out farm equipment stores like tractor supply, or even batterty stores like battery plus... the space and weight is only a slight increase, where the benefits/advantages are well worth the transition.
