Battery Charger Voltage
Has anyone pulled voltage on their battery charger? with the breakers on for the charger and disconnected from the battery, I am only getting 2.6 Volts on my voltmeter for the starting battery terminals. I'm getting 12.6 for my house battery. What is the normal range they should be putting out for each? For a reference I pulled voltage on my bench top battery charger and at 2 Amp setting I am getting about 10.5 volts. Is the charger shot? IF so anyone have an install guide for replacing one of these as it is funneled into a large harness that goes in every direction.
Thanks
Thanks
2001 Fiesta Vee 242. 350 MPI. B3.
Post edited by MXZ0588 on
Your batteries are made of six 2.1vdc cells, totaling 12.6vdc.
Your charger cell is showing 10.5v, and has a dead circuit, making the total 10.5vdc. time for a new charger.
