Odd RPM jump and single beep
Ezgoin
Member Posts: 80 ✭✭
3 times yesterday while idling, my RPMs jumped up for 1-2 seconds, I got a single Beep, then the RPMs dropped back to normal and everyting was fine. What might be causing that? (2005 262 Captiva with the 8.1 liter and Bravo 3)
pick up a fuel pressure gauge- the analog kind that screws into your fuel rail via the valve port, and that logs the highest pressure reached during operation... you're looking for ~consistent~ pressure across the entire RPM range and regardless of load... your pump and regulator are 'sposed to maintain a precise pressure to the injectors, else they've no means of adjusting trim accurately...
hopefully you rule the pump and regulator out- and if so, look at cleaning the IAC with throttle body cleaner... if that checks out, look for a vacuum leak by carefully spraying ether/staring fluid around the intake manifold mating-to-heads-and-block area in very short bursts on a running engine.
