Helm USB charger install
LaRea
Member, Moderator Posts: 7,567 mod
I just installed a USB charger in my helm -- thought I'd share the details.
The charger replaces a 2" analog clock on the right side of the helm, next to the cupholder where I usually keep my phone. The clock didn't work, and I normally read time from the VHF anyway, so I didn't need the clock.
The charger is a panel-mount 2-port charger like this:
To keep the original look, I re-used the clock housing and bezel. I wasn't certain it would work, but I knew I had the fallback plan of buying a blank 2" gauge from Faria for $20, so I went for it.
I used a Dremel tool to cut an access hole in one side of the housing. With pliers, I ripped out the clock guts. Then I used the Dremel to cut away some internal bracing to make room for the USB charger. I also cut a hole in the back side for the power plugs.
The charger is smaller than the clock face, so I used a 1-1/8" spade drill bit to drill a hole in the clear acrylic gauge face. Some of the face is visible around the edge of the charger, so I applied black spray paint to the backside of the face. The charger has a plastic lock nut that snugs up against the face.
The result looks like an OEM installation, and it only cost me $10 plus 1.5 hours of labor.
I'm planning a similar install on my helm and down below next to the existing cigarette lighter socket.
