FV342 - 12v Systems - no power unless on shore/generator power
Hi all - I have a perplexing issue. While trying to drop anchor, (not on generator) I lost all 12V Systems.  The 12V systems will now only work on generator power or shore power.  I have checked every breaker - none are tripped.  Is there a fuse somewhere that I am missing - with the exception of running down every 12v line, I feel I have looked everywhere.  Any help would be appreciated!  Thanks
  • LaReaLaRea Member, Moderator Posts: 7,953 mod
    Do you have a way to measure the voltage at your 12V receptacle?  Is it really zero volts?  Or do you have some voltage but just not enough to operate any of the systems?
  • MarkBMarkB Member Posts: 3,997 ✭✭✭✭✭
    That is probably because the charger is converting 110v and powering your 12v systems. Sounds like your battery is fried.
  • miamirinkermiamirinker Member Posts: 8
    I never thought about a toasted battery. I have no 12V to the whole panel - 0V. I'll load test the batteries. Can anyone confirm there are only circuit breakers and no fuses between the batteries and the panel?
    Only breakers that I know of are main breaker on panel in the cabin and 2 breaker in the panes astern just as you walk in. You might want to check the connections on your house batteries.
    I definitely will - thanks for the feedback.
    If you get 12v on a meter at the battery, get it load tested. If it shorts internally under load you will have the same issue.
    If it is a battery: replace both and of the similar kind. Depending on your charger you could switch to AGM types.
  • raybo3raybo3 Administrator Posts: 5,579 admin
    If it was a fuse or a breaker then you would not get the 12vdc from the charger either. My guess is you need a new battery. Good luck and keep us posted.....
    You make a great point raybo.  I'm hoping to get back there tomorrow or Wed & will definitely post the diagnosis.
    I don't think it's the battery.....he would have noticed that it was slowing down. My bet is that he has a loose or bad connection. Sort of like a bad ground on a car....you turn the key and the starter clicks and then there is no more power. Windless is a high amperage draw and a bad connection would act just as stated.
  • PairADicePairADice Member Posts: 74 ✭✭
    im guessing batteries are fried too...
    There are 2 breakers by the battery switches
    One house battery appears to have shorted across plates and must have a dead cell.  Voltage is really low and non-existent under load.  Other battery dead enough.  Have new batteries, but won't be installed for a few days.  Thanks to all for the help/ideas!
  • CrewLoungeCrewLounge Member Posts: 92 ✭✭
    You lost your ground.
    All's well with new batteries. Again - thanks to all for the help
