Battery Switches
SeaShift
Member Posts: 27 ✭✭
I have 2003 312 Fiesta Vee. When i turn on the port battery switch i get nothing from either motor. When i turn on the starboard switch both engines will start.
The reason i found this is because I'm getting what i believe to be a low voltage alarm from the port engine when using the spot light or drive trim, the voltage drops dramatically, tach drops off and the alarm sounds. Goes away as soon as i turn off whatever electrical device I'm using . I initially thought the alternator was gone on the port motor... Alternator tested fine. Load tested all the batteries and all are good to go. Is it possible somehow both engine are running off of one battery. Maybe the port switch has failed completely, maybe both switches are messed up. Any ideas would be greatly appreciated.
Does anybody have a good schematic diagram of how Rinker sets up the batteries, switches and charger on twin engine boats? This is another topic that should be a sticky note.
@frenchship, is that the same diagram you got from Rinker?
I also got the full wiring diagram from Mercruiser for my 5.0 MPI . I had it enlarge 24x24 poster size and l had it laminated it is in full colour.
