Replacement bilge pump
                    Need to replace the bilge pump in my 1998 232 Captiva CC. Anyone know of an easy to install substitute? At the least let me know what the diameter of the hose used on this model boat so I don't buy something that won't fit. Just purchased the boat so this is all new to me.
Thanks,
Randy
2019 MTX20 Extreme
You are best to take the old one out, it should just unclip from its base. Then get the hose size.
I just had the most exhausting CG boat safety insepection ever last weekend and the guy said I should have a light or 'sound' to alert me if the bilge pump is running. Interesting idea, but how do you manage that with an auto pump set up?
Randy, on mine, the pump was a cartrige type that with a quarter turn or so lefty loosey it comes out. I want to say it was a Johnson. Whatever it was I got the same brand and it fit back in the same place, same hose size. I did have to do a little modification with the auto-on switch but that was cake. I may have had to unscrew the mounting bracket from the bilge but that's easy too. This is a good chance to upgrade in capacity. I about doubled what Rinker put on mine.
Black_Diamond, my bilge switch light turns on when the auto-on activates. It's a dim light that I can only see when I'm doing something like going under a bridge, but it's there. So technically you can tell the CG to go _____.
