Throttle control
MarkB
Member Posts: 3,999 ✭✭✭✭✭
I troll (fish) with my boat. Sometimes I need to keep a speed in between idle and where the throttle lever sticks (springs back to idle).
I then need to hold the throttle arm which is a bit tiresome.
Have a single Mercruiser 350MAG.
Is there anyway to get the throttle leaver to stick a bit more?
Also I'm busy installing a smart gauge from Mercruiser. Seems like this has troll control. Does anyone know what the min rpm you can set the troll control to work at? I need to get down to speeds of around 2.5 mph at times.
Hmmm.....Lake Ontario.....2.5 mph......salmon??? If you can attain trolling speed with your current setup then the Smart Gauge in troll mode should work. It looks like you can dial up either an engine speed (rpm) or boat speed.
Back in the day, I used a 9.8 hp kicker outboard mounted to the stern. A PITA but I was able to hold the boat speed to 2.2 mph for the lures we were dragging.
Mark
2019 MTX20 Extreme
2019 MTX20 Extreme
Partsman, when you say it won't stay, do you mean it goes back to the middle? There are adjustments at the engine for the throttle and shift cable. Also, you both might want to see that when you shift into forward that the throttle cable does not advance thus giving you a higher throttle clicked in gear. I beleive in the shifter itself it will initially advance the shift cable then throttle.
Every thing is fine other than 1/2 the time I have the hold the throttle so it don't slip back into neutral.
Do you have a link
Here is the link to the manual. I have the tachometer unit.
http://www.mercurymarine.com/media/mercury/documents/SmartCraft_Gauges_Owners_Guide.pdf
Mark
