BATTERY SWITCH
minnesotaminnesota Member Posts: 67 ✭✭
edited May 2015 in Electrical Discussions
Please help,  Rinker techies .  We just purchased a 2008 280.  Loving the boat but I believe there is a wiring problem. The boat has
Battery switch= Blue Sea E-Series Circuit Plus.  3 positions  "OFF", "ON", "COMBINE"
3 batteries, 2 in parallel.
When the battery switch is at the ON position; even with ignition in ACCESSORIES position:  no radio, no horn, no accessories, no CO detector, no power to anything
When the battery is at COMBINE: everything works fine.
Obviously, I don't like to run the boat on COMBINE. Please help, what's wrong here. Can I remove the panel from the aft-port side to rewire? working at the back of the panel is not an option (no room).
Thanks
2008 280 EC
