Starter problems - 1989 captive 6 cyl.
stinger536
Member Posts: 16 ✭✭
Tried to fire up my boat today with a fully charged battery that I bought last fall. Starter won't turn over the engine. Doesn't have the "click" sound like a dead battery and I hooked up my 200 amp charger to try to start. I'm sure that I winterized correctly, this is not my first time. Any ideas?
his is the first time that I've tried to start it this spring.
The reason I brought this water pump issue forward is that a local guy here just had this very thing happen to him. He bought new batteries, chased wiring all the way to the starter, was hot as he could be.. The stator was engaged, but the starter just wouldn't turn.. he pulled the starter and had it load tested, checked out fine.. he got a new one anyway, and had same issue..
He had a moment of clarity, and pulled the plugs out and tried it.. even w/o compression, it wouldnt budge. He decided to pull the engine and strip it. He pulled the belt off, and all the sudden it rotated like it was cool... Decided to pull the w/p and front cover, only, it didn't like that idea very much... After much argument between he and it, and some heat via torch, he gt it off... The impeller was bonded via corrosion to the housing. Go figure. It's not something I would have guessed either, but now knowing, I can easily see it could happen.
Not fun, but it can be completed in about an hour. It could be something as simple as loose battery connections
Thanks for everyone's help!
