342 air horn installation
I have a couple of questions regarding installing an air horn on our 342. (The stock horn is quite wimpy)
1. Is the horn switch rated for 20amp
2. Where would the best place be to pickup power? I wondered if I could use the existing power supply and change out the 5amp breaker with a 20
Thanks for the information. May be a couple of weeks, but I'm going to give it a try.
Either way, make sure the horns are pointed down so they won't collect water.
If you mount it on the side, make sure it's not going to interfere with the walkway. My 370 has it mounted on the side of the foredeck. It gets in the way every now and then, but mostly I don't notice it.
One thing with the AFI: assume that you'll occasionally get some rain or spray splashed into the hose. If it drains directly into the compressor, the compressor will eventually corrode and fail. Mount the compressor with the hose pointed down so any water will collect at the lowest point of the hose rather than dripping into the compressor.
http://www.kahlenberg.com/products/marine-signaling/commercial-military-horns
