OK, got to fix the TV-
rasbury
Member Posts: 8,886 ✭✭✭✭✭
I have seen some other threads over the last year about replacing the tv''s with led to save power, how much better the new TV's are etc. etc.- Here is my deal: the tv works (comes on) but we only can watch DVD's since the change from digital. I don't want to have to re do the cabinet to install a better tv unless fixing the one I have is the same cost to upgrade. We just don't use it that much but would like to watch the news in the AM. So, I knocked the antenna off the arch so I have to replace that with something, wish I could mount in a better place, then I need a converter of some sort to get a signal?
If you use the threaded mount for the tv/radio antenna you can take it on/off pretty easily.
a new Omni directional antenna is pretty inexpensive. I would suggest a new tv. it will use less power and have the atsc tuner built in. I connected mine last weekend and got 5 local channels in hd. our tv has a built in dvd player so no extra space needed for that.
best buy has Insignia combo units 20", 24" and 28". $140-$190. I known in the past LG made all of the Insignia product. Best of the Korean manufacturers.
Thanks, I will up date this with the final purchase as I'm sure all this stuff is changing all the time. It runs off shore and the battery so I need the dual voltage and assume the new ones will have the converter. I hope what ever I purchase will fit into the cabinet I have now as I don't want to have to re invent that area and it will also have the converter built in and will then need just the antenna. We have a vacation planned for late July and want to have this in as we will be a week at a marina.....
Here is the TV that came on my boat.
06 Rinker 270
