Help No Water
buggyjdav
Member Posts: 134 ✭✭
New to us 04 342. Had her at the fuel dock overnight, filled fresh water tank and used the water all night and all morning (no city water hooked up), worked fine. Disconnected shore power and moved the boat 50 yards to a different slip now no water... Hook up city water and it works fine.
The pump runs continuously and seems like there is air in the line as it spits water a bit but not even enough to use. I unscrewed what looked like the filter from the pump (clear round thing on bottom but there wasn't any screen or anything inside, not sure if that's normal.
Unscrewed the fill cap and flushed it and the air valve next to fill, still nothing...
Any ideas? Please and thank you.
Still no water, I see water and air pockets pumping out of the pump through the clear lines but no water at any faucet.
