Help STBD Engine Overheating
buggyjdavbuggyjdav Member Posts: 134 ✭✭
Sitting at dock warming engines up and Stbd engine alarm went off, temp approaching 240. Checked coolant, seacock and strainer. All is normal.Did start/stop the engines several times before the alarm went off but wouldn't think that would cause it. Any ideas would be appreciated.
  • LaReaLaRea Member, Moderator Posts: 7,876 mod
    Can you see water moving through the strainer?  Or remove a hose and crank the engine to see if it's pumping water?  The usual culprit is a failed impeller in the raw water pump.  Do you know how old the impellers are?
  • buggyjdavbuggyjdav Member Posts: 134 ✭✭
    Thanks Larea, doing those checks now. I don't know how old.
    Took strainer out, nothing blocking water flow, no moving water when engine is running so impeller went. Thanks for the help guys!
  • raybo3raybo3 Administrator Posts: 5,553 admin
    You could also remove the end caps of your heat exchanger and clean it out. Does not take much to cause the engine to overheat.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,748 mod
    When was the seawater pump impeller last changed?  I usually start there for any overheating issues.
    Not sure. Just bought her.
  • EaglesNestEaglesNest Member Posts: 30 ✭✭
    most likely seawater pump.  Had same issue 2 weeks ago. can try taking off all the hoses to make sure there is not an obstruction as well.  but seawater pumps should be changed about every 2 years if you don't want problems.
    I'm seeing so many impeller and thermostat failures that it boggles my mind. I would definitely have the impellers and thermostats replaced on any used boat I purchased in the future, before it hits the water. I would even care if someone told me they just replaced them.
    Decided that I don't have the time to tackle this. Had marina replace both impellers..  $750 total... Then the phone rings... Both water pumps are shot, add another $1500 cha ching. Will replacing both pumps also assure thermostat is replaced or do I need to tell them to do those as well?
    Um, I'll be the first to say it ... $750 to replace impellers is obscene.  I could do them both in 90 minutes, and I'm not that good.  A pro could do them in an hour start to finish.
    At those rates, I'd say keep your existing thermostats.
