Replacing Indirect Lighting
DanD2
Member Posts: 848 ✭✭✭
So I replaced my battery zapping indirect lights with UV LED's this past weekend....I like them...What do you guys think? No longer a boat owner.....previous boat - 2005 Rinker Fiesta Vee 342
It was pretty easy, the hardest part was getting the type of lights that I got to stick. I got side emitting lights and the sticky part is on a very thin film. Next weekend I'm going to pull them down and put 2 faced tape in then stick the to the tape. That should be a much better solution.
The old lights are held in place with staples and sometimes you've got to yank pretty hard to get the off but it's pretty easy.
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
Looks good.
Same here.
I bought the side emitting UV led's from superbrightleds.com. I like the light but am not happy with how they stuck, or should I say didn't stick to the underside of the shelf. They worked fine for the galley but not so good for the v-berth. As stated previously, I'm going to use double side tape this weekend and am pretty sure that will work ok.
I'm trying a different style of UV for the aft cabin from oznium.com. I'll report back when I get them installed.
