Dragging and squeaking
I took my '03 Captiva 232 out for the 4th time this year, and had a little issue. It's a 350 Mag/Bravo 3, and I had both batteries fully charged before going. When I went to start the boat, the starter was dragging badly, and there was a very loud squeaking while the engine was turning over, and not starting. The engine eventually started, and continued squeaking for 5-10 seconds, and sounded similar to a belt squeaking, although I'm not sure the belt can squeak while the engine is cranking and not running?
I shut the engine off, and restarted it 7-8 times with no issue throughout the day. No dragging, and no squeaking......100% normal. Then, out of nowhere, it did it again. The starter was dragging, there was squeaking, and it didn't want to start. Once it finally did star, it was fine, and started normally for the rest of the day.
Thoughts?
Thoughts?
