Jabsco Marine Toilet Problem
My Jabsco electric toilet does not always empty. Sometimes it does, sometimes it doesn't. When it doesn't empty, if you wait for a while eventually water can be heard for a second (sounds like it is filling the discharge impeller chamber), then it will empty. Motor is running fine, just installed impeller kit (including joker valve), and verified vent is clear. Is it possible that the large discharge hose running to the waste tank is partially clogged? If so, how could a clog go through the chopper and joker valve? This is a 16 year old boat.
